Bottle heater options
Old Mar 9, 2014 | 10:34 AM
LsoneGT's Avatar
Default Bottle heater options
Im in the market for something to warm my bottle, and interested to see what everyone uses. Not looking to hardwire anything into the car so was curious if there is a option for a heater that just plugs into a 110 outlet of cigarette lighter etc.
Old Mar 9, 2014 | 11:45 AM
HCI2000SS's Avatar
What kind of kit do you have? I run a automatic pressure controlled heater from NX myself
Old Mar 9, 2014 | 11:49 AM
LsoneGT's Avatar
Nitrous outlet plate kit
Old Mar 9, 2014 | 12:40 PM
03EBZ06's Avatar
Usually heaters draw a lot of amperage. Going to have to use a relay from a fused power source direct from battery. I don't think a cigarette lighter will sustain the amp without popping a fuse or melting the wiring to the cigarette lighter.
Old Mar 9, 2014 | 02:18 PM
JDEP162's Avatar
this^^^ i have the heated bracket from the outlet works great
Old Mar 9, 2014 | 07:23 PM
LsoneGT's Avatar
So I have to hard wire something permanent in the car?
Old Mar 9, 2014 | 08:45 PM
tyler ovel's Avatar
You should
Old Mar 9, 2014 | 09:45 PM
LsoneGT's Avatar
I think I found what I need. I can just plug this into a 110v outlet.
http://www.nitroussupply.com/proddet...d=24164&cat=91
Old Mar 10, 2014 | 10:45 AM
02streetsweeperSS's Avatar
How long are you planning on keeping the kit on the car? You have already wired a nitrous kit up, might as well wire a bottle heater too.
I use the Nitrous Outlet bottle heater too.
Old Mar 10, 2014 | 10:55 AM
LsoneGT's Avatar
Its strictly a drag car so just need the bottle heated. Im not wanting to use a torch like everyone at my track
Old Mar 10, 2014 | 11:02 AM
manfred717's Avatar
If you have a trailer, I would suggest using a hot water bath. I prefer to use as water bath when I can.
Old Mar 10, 2014 | 11:35 AM
brandon@nitrousoutlet's Avatar
This would solve your issue and keep you from having to put a heater in the car.
Old Mar 10, 2014 | 11:36 AM
LsoneGT's Avatar
Not familiar with the bath is it something you buy or a homemade setup?
Old Mar 10, 2014 | 11:39 AM
http://www.nitrousoutlet.com/nitrous...le-warmer.html Here ya go.
Old Mar 10, 2014 | 11:42 AM
LsoneGT's Avatar
Thats bad *** Brandon thanks!
Old Mar 10, 2014 | 11:45 AM
ss performance's Avatar
There is a company out of Port Orange FL, (Daytona area) that makes a lot of different bottle warmers. ARC, Applied Race Components. They make both 12Vdc and 120Vac as well as dual AC/DC warmers.
I can't find their web site, they do have a face book page, but I have seen their stuff on Ebay.
Old Mar 10, 2014 | 12:21 PM
LsoneGT's Avatar
^ thanks ill look into them as well
Old Mar 10, 2014 | 11:05 PM
NOS LS1's Avatar
Default 12/ 120 V Nitrous bottle heater
They say that this is one of the best bottle heaters out there. its very reliable.
Runs on 12 Volt or 120 Volts. 120V can be used in the pitts with a generator.
http://www.ebay.com/itm/181340965173
