STOCK WS6 wanting to spray
Old Mar 18, 2003 | 08:50 AM
99MONGOOSE's Avatar
Default STOCK WS6 wanting to spray
My 2000 WS6 is stock other than a cut-out, hood baffles removed, and a SPEC STAGE 3 carbon clutch. I want to keep this car emissions legal; therefore, I was thinking spray, rather then H/C. I would like to spray 100-150 TnT wet. Heres my thoughts, please advise if I am missing anything AND please add your thoughts too!
-TnT F1 kit
-MSD window switch will be set for 3000-5000(?)
-Wide open throttle switch
-Fuel pressure safety switch
-NGK-TR6 plugs
-bottle heater
-RAM 910/402 VDS clutch
-Moser 12 bolt w/ 4.10 gears, HD Eaton Posi, 33 spline axles, T/A cover
-Pro-5.0 shifter w/ LSS
-Texas Speed and Performance lid
-Brian Green RAM AIR Mod
-LG2 torque ARM
-LG LCA
-BMr tubular SFC
-26x10.5x16 ET streets w/ skinnys up front
Old Mar 19, 2003 | 07:26 AM
99MONGOOSE's Avatar
Default Re: STOCK WS6 wanting to spray
ttt
Old Mar 19, 2003 | 11:37 PM
wicked 98z's Avatar
Sounds real good. You might want to add a inline pump just to be safe.
Old Mar 20, 2003 | 12:16 AM
Screamin_Z's Avatar
I could be wrong but I don't think u need the window switch AND WOT switch. I think it's one or the other. if it is go with the window switch with a max RPM set at about 5400-5600 if u have stock rev limiter. I'd replace ur springs and pushrods, and then when u get ur computer reprogramed get ur rev limiter set at 6800. then get ur window switch at 6200-6400. u'll love it. oh, go with 4.30 gears. those are fun for nitrous and motor.
Old Mar 20, 2003 | 12:18 AM
Screamin_Z's Avatar
one more thing. u don't need to buy a LSS the 5.0 has plenty of thread on it. so just do what I did and cut the majority off the stick, there ya go. u have a homemade LSS. it'll save u some $ too. don't worry about cutting the stick straight, it'll be hidden by the shifter ****.
Old Mar 20, 2003 | 12:22 AM
Screamin_Z's Avatar
forgot one more thing. u'll love the RAM clutch. I have the same one that I bought from Futral Motorsports, great people there. I called them ALOT and allen and his wife are awsome. he answered every question I had before and after the purchase. I'd buy from him, u will not be disapointed. he's a sponsor on here.
Old Mar 20, 2003 | 02:15 AM
Black00Z's Avatar
I say go with the WOT switch and the window switch. You should really only run nitrous at WOT, and obviously you want to limit RPM range in which you spray.
Besides, there's really no harm in taking extra precautions.
