My nitrous install thread...!
Old Apr 20, 2014 | 04:42 PM
  #41
tuckin22's Avatar
pretty nifty.. have been thinking of jumping on the spray wagon myself... didn't realize how much thought had to go into these setups... would be fun though.. good luck..
Old Apr 21, 2014 | 05:15 PM
  #42
BSmiff's Avatar
The only problem I see with mounting your microedge allllllll the way over there is you gotta either:
A)Have extremely long arms to change your ramp on the fly
or
B)Get out of the car and walk around anytime you want to make adjustments
I would want my progressive somewhere close within reach so if Im at the track and I see a bunch of people knocking the tires off I can change it on the fly.
Old Apr 22, 2014 | 09:48 PM
  #43
slammin86's Avatar
Thanks
or
I'm not running a progressive controller.
Old Apr 23, 2014 | 01:53 AM
  #44
DSS's Avatar
DSS
nice set up man and good work
Old Apr 23, 2014 | 03:05 PM
  #45
BSmiff's Avatar
My bad I thought the Microedge was more like the Leash Controller. How long til this thing is cookin on the highway.
Old Apr 23, 2014 | 09:50 PM
  #46
slammin86's Avatar
Thanks
Well my rear end setup and gears only have about 300 miles on them so I am still taking it easy. I have also changed plans slightly and ordered a 15 lb bottle. The goal is to have the rest of the kit installed by this weekend minus the bottle.
Old Apr 24, 2014 | 06:27 PM
  #47
slammin86's Avatar
Might not look like much but I actually made great progress today. Made my harness that is going to the trunk and got it all routed through the car. This consisted of removing the rear seats, rear side panel, front kick panel, and trim beside the door.
I also found the perfect place to mount my terminal strips...they will be super accessible yet hidden out of site. Very happy with this find.
Also figured out what area of the glovebox I can cut out to route the wires through.
Anyway, here are a few pictures.
Sorry about the dirty gas tank.
If you notice the tape measure in the first pic you will think I am crazy. I was putting a ziptie every 8" on the harness. I was also able to ziptie it to the factory harness inside of the car.
Although it does not look like I have made much progress at all on this thing, the hardest part is behind me. That was the planning.
Old Apr 25, 2014 | 06:58 PM
  #48
slammin86's Avatar
Made a little progress today.
Had to replace the braided like with a hardline crossover on the fuel rails.
Then started installing. Didn't get very far.
Old Apr 25, 2014 | 08:52 PM
  #49
Rise of the Phoenix's Avatar
You are a ******* master with your craft sir. I am so torn between continuing with my nitrous build or saving to go a Procharger build.
Old Apr 28, 2014 | 05:09 PM
  #50
tuckin22's Avatar
pics no worky...
Old May 5, 2014 | 05:52 PM
  #51
slammin86's Avatar
Anyone could do what I am doing...just takes time and planning.
pics no worky...
They work now. Photobucket said I was too popular.
Old May 5, 2014 | 07:16 PM
  #52
tuckin22's Avatar
haha yeah man lookin good.
seeing just the thought in this, it is going to come out both sic and perform as well.
Why you ditch the braided though? Gonna cut it close with your throttle cable or something like that?
Old May 6, 2014 | 12:12 PM
  #53
slammin86's Avatar
I looked at running the braided under the throttle body but there wasn't enough room.
The problem with the braided above was the hardline kit for the plate was going to interfere unless I did some ridiculous tall braided hose that would have rubbed the hood lol. I think the polished hardline will look even better when I have the other hardlines in that area.
Old May 6, 2014 | 06:19 PM
  #54
tuckin22's Avatar
Ahh got ya... Yeah definitely will look good with more... you gonna do as much hardline as possible?
I know that hardline is a lot more work and harder to make look good, but when you take your time it is well worth it.. as far as looks go...
Old May 6, 2014 | 09:54 PM
  #55
hrcslam's Avatar
Your Goat is gorgeous!
Old May 6, 2014 | 10:54 PM
  #56
JJ_TURBO's Avatar
11 Second Truck Club
Nicely done, you got good skills and ideas, what fittings and line did you use on the fuel line? are they -8an and 1/2" ss line?
Old May 15, 2014 | 07:29 PM
  #57
slammin86's Avatar
Got one of the big bottles...the other will come shortly...
Old May 15, 2014 | 07:31 PM
  #58
slammin86's Avatar
I do not plan to hardline anything else. Just the fuel crossover and the solenoids to plate. I plan to do a standalone at some point in the future so for now I am just going to run braided hose from fuel rail to solenoid.
Thank you.
The hardline is -6 and 3/8".
Old May 17, 2014 | 07:28 PM
  #59
slammin86's Avatar
Well it really is unfortunate how slow this install is going. Worked on it for a few hours today.
Had to modify my billet bottle line wingnut (cut the ends off) to make it work with the remote opener. Also had to clock the top of the opener to make it work in the trunk. Assembled the bracket and installed the rubber pieces on it to keep the bottle from getting scraped up. Also installed my new 45 degree inlet fittings on the solenoids and got the fuel solenoid mounted. Sourced some nice black allen head bolts and washers for the solenoids to brackets.
Old May 17, 2014 | 08:48 PM
  #60
slammin86's Avatar
