Bad day at the dyno with a 5177
425rwhp, 367rwtq <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Torque is pretty bad but I assume that from my ultra lean condtion. I'm actually suprised I didn't hurt anything. The 100 octane I was using might of saved me. According to the A/F ratio on the dyno, it's over 17 !!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> My AF looks like a roller coaster. The graph shows 16.5:1 at 50-65mph then goes to 13:1 at 70mph then jumps to 17:1 after 75-90mph then goes to 16:1 after that. I don't have a scanned copy yet but I'm curious why I'm running so lean??? I had my PCM updated and my run without nitrous was a lean 14:1 all the way across. My last run with my old PCM config was 12:1 (same mods). I checked my FPSS and made sure it was ajusted properly and that seams to work fine. It's not surging. I went down to a 100 shot with similar A/F ratior results. I'm running a Walbro 340 in tank pump, stock injectors. The only thing done to the engine is maf ends, lid and Magnaflow cat back. Is my new PCM config (GM) causing the problem? What else can I do?
I'll try installing my stock maf ends on too.
Thanks guys!
