What NGK part# for non-projected tip -9 -10 -11 heat range plugs L92/LS3 Heads
Hey guys,
Can someone give me the part number for Non-Projected Tip -9 -10 -11 heat range NGK plugs for L92/LS3 cylinder heads.
Thanks,
Thanks,
#1085 is a taper seat non projected NGK in 9 heat, I just looked up replacement plugs for a LS3 and they are taper seat
Go below NGK Spark Plug reference chart PDF , this should help , The first one is part number and the second is how to read the part numbers , like tapered seats and so on . Any one running NGK plugs needs these charts
http://www.ngksparkplugs.com/pdf/StocktoPart11x17.pdf
http://www.ngksparkplugs.com/docs/te...bols_plugs.pdf
NGK Racing Plugshttp://www.ngksparkplugs.com/docs/RacingSpecs2013.pdf
