Nitrous/Texas Giant guys... what compression?
Old Jul 1, 2014 | 12:22 PM
GTA91's Avatar
Default Nitrous/Texas Giant guys... what compression?
I've been running this cam in my 402 since 2006 with good luck. I've ran it NA and with nitrous along with a stalled auto and a T56. It usually goes high 10's NA and 9.8-10.0 on a 200 jet at 3650#'s.
My motor has always been about 11:1, currently its 11.2:1... and I honestly forget what my dynamic compression is. I might be pulling the heads here soon and doing lifters and gaskets, curious if I should up the compression. I'm thinking I'd like to be more like 12-12.5:1, but I know its really just about dynamic.
I'm running a nitrous outlet 90mm plate and I have a standalone system with c16 in it along with BP 93 octane in the stock tank. This is a street car and I want to keep it on 93 octane (NA).
Curious what others are doing with this cam... thanks in advance. Trying to get the car ready for Hot Rod Drag Week, so I'll need to figure this out quick if I want to change things up.
Thanks!
-Jeremy
Old Jul 1, 2014 | 01:52 PM
ATwelveSec02Z28's Avatar
Just remember tightening the quench and/or making the chamber smaller will make the tune up more sensitive to timing.
But in general, the more compression the more power...
Old Jul 2, 2014 | 02:01 PM
GTA91's Avatar
Where are all the Texas Giant/Nitrous guys?
Old Jul 2, 2014 | 02:20 PM
brandon@nitrousoutlet's Avatar
Why not just go up on the nitrous jet if you're looking for more power? Our shop car has that same cam with 13.5:1 compression. If you want to keep the car streetable and run 93 octane pump gas just stay where you're at compression wise.
Old Jul 3, 2014 | 08:31 AM
GTA91's Avatar
Brandon, thanks for the feedback. I've talked to you guys a few times over the years about my setup. I'm not really looking for extra power, just figured if I can optimize my setup a little more while I have the heads off, then I would. This setup was kinda "thrown together" back in the day and has done me well, but I've always wondered if I'm leaving much on the table with lower compression. I really need to calculate my dynamic compression, what should I target?
