New to nitrous and need info lots!
the motor is just a 5.3 with 90k miles stock right now will add nitrous cam later on. Goal is low 6s in 8th mile maybe a 5 second pass on the stock bottom end we see forced induction guys do it and i would like to accomplish this on the bottle! car will be ran on microsquirt and E85 for fuel.
1.) what solenoids do i need? and it is a wet kit
2.) nozzle or TB plate system?
3.) activate it off TP?
4.) what kind of A/F am i looking for?
5.) line size?
6.) is it safe to activate off trans brake? i know your not suppose to hit rev limiter on nitrous y I'm asking.. noob question?
7.) any more info that I will need to get this going to the low 6s in a 8th!
car will weight right at 2900#
thanks in advance and keep in mind i want keep this kit very safe to me and the car!
5.) line size?
1.) The solenoids included in the system will match the plate/nozzle, so don't worry about that.
2.) A nozzle will do up to 250 HP, and the plate will normally do around 400 HP. As fast as you are planning to go, you will need to spray a significant amount of nitrous, and a direct port may be a viable option for you.
3.) The nitrous system will normally activate off of WOT. However, you can set up an RPM window switch so that it has to stay within an RPM range that you set.
4.) You want to tune the car for at least .5 point richer than what it runs WOT on motor. Normally a 12.0-12.5 is acceptable.
5.) The line size in the system will match the rest of the components and flow rating of the system, you will probably end up with 6an.
6.) Yes, you can activate of the t brake, there is a wire on our relay for a transbrake input that will keep the system from activating until you let off the brake. The RPM window switch I mentioned earlier will keep you from hitting the limiter on nitrous. Well worth the cost in my opinion.
7.) If you have anymore questions please let me know!
-Garrett
5.) line size?
1)I would run our .122 nitrous solenoid(s) with our .187 fuel solenoids. The number of solenoids will be determined by what type of system you choose.
2) You're going to need either a plate like our Stinger,our Puck system or a Direct Port System.
3)I'm not sure what type of car this is going in. Assuming its a 4th gen F-body, you can use the TPS to activate the system. This would require you to run some sort of TPS activation switch. We have the NOS TPS/Window switch available or the NOS Mini Progressive is another good option that has TPS activation.
4) Tune it from reading the plugs. USe the wideband as a reference.
5) 6AN Main feed line.
6) You can wire the system to fire as soon as you let go of the trans brake. I have wiring diagrams available for this. Just PM me your email address and I can send it over.
7) There are a lot of variables here that need to be answered. What transmission are you planning on running? Is this going to be a bone stock 5.3? What intake? What heads? What is done suspension wise on the car? You will have to cram a fairly sizable shot into that 5.3 to run the numbers you're looking for.
car is a 92 mustang weight is around 2900#
2.) transmission is a power glide not sure on stall converter?
3.) this is a stock 5.3 on microsquirt. will be adding a nitrous cam once i learn more on the subject!
4.) intake is a stock 5.3 truck intake for now but i am open to using a LS1 or holley intake with direct port.
5.) car has full UPR suspension currently know a few people with same setup cutting 1.2-1.3 60s only change is they run th400 not a power glide.
Do you guys know if there is anyone successfully running 200 shot on a stock bottom end 5.3?
NITROUS:
No multiple stages permitted.Second kit must be removed
No progressive controllers or controlling nos flow electronically in any
way.
No Pusher systems of any kind, No nitrous chillers, Bottle temperature must top to bottom.
All nitrous solenoid grounds must be grounded in engine compartment and
visible. ( in plain sight)
Only 1 nitrous bottle allowed in car at a time.
No "leaking" nitrous in any way in any location.
Purge plume must be entirely outside of the engine bay and directed
upward.
Big Block OEM Block Nitrous entries maximum jetting
1 jet .076
2 jets .053
8 jets .026
Big Block Aftermarket Block
1 jet .068
2 jets .048
8 jets .024
Small Block Nitrous entries maximum jetting
1 jet .082
2 jets .057
8 jets .028
car weight for this class will be 3100# fast cars are going mid 5s.
He is using a single nozzle setup with a truck intake. -Garrett
This is what I'd like to do...if you could PM me a way to get in touch with him that would be great...I suppose I can just call tomorrow also...
(Sorry about the thread hi-jack...)
You could do something like have TunerStudio control like a 100-150 dry shot off the line (depending on your fuel pump/injectors), and then have another 2nd wet kit kick in on a seperate controller after the 60' (sample).
But I would recommend anything over 150 shot just go to a stand alone system and not use Tunerstudio to control the N2O...
