WOT microswitch bracket for fast 92 TB
Old Aug 8, 2014 | 02:53 PM
GiggleJuiced_SS's Avatar
Default WOT microswitch bracket for fast 92 TB
who makes one? I have stock 799 heads. fast 92/102 setup. thanks.
Old Aug 12, 2014 | 10:27 PM
74u's Avatar
74u
I couldn't find anything either so I made one. For my fast 92/PTM95mm t-body I just bent a 90* out of aluminum strap (used for making fuel cell straps) and mounted the switch to one side of the bracket, and drilled a hole in the other side so it could sit under one of the t-body mounting bolts. Works perfectly and looks very clean.
I'll send pics if it would help...
Old Aug 13, 2014 | 08:40 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
We don't sell one, we normally use ours and mount it under the gas pedal, or you could bend our bracket and probably make your own that way. Sorry I couldn't be of more help man.
-Garrett
Old Aug 13, 2014 | 10:48 AM
Sure. I'd be interested in seeing them.
Old Aug 14, 2014 | 08:09 PM
74u's Avatar
74u
Easy and cheap. A little rough as I made it with a bench grinder and plugged the wheel with aluminum. Could use a little polishing but it works perfectly and stays put. I just started with a 1.5" x 1.5" 90 degree part, cut the radius to match the t-body and started drilling holes.
Old Aug 15, 2014 | 02:16 PM
Cool. Want to make me one?
Old Aug 15, 2014 | 05:55 PM
74u's Avatar
74u
Are you local? If so it's gonna cost you all the beer I can drink during making/installing
Old Aug 16, 2014 | 01:11 AM
No lol I'm in Pa. I'll pay ya something for it and send it to me. How does it mount to the tb?
Old Aug 16, 2014 | 07:05 AM
74u's Avatar
74u
I'd be glad to make you one but is your throttle body, and throttle cam identical to mine? If not the bracket may need tweaking on your end, or another good possibility is it may not fit at all.
It mounts under one of the throttle body mounting screws...using the radius of the throttle body to lock the bracket in place and prevent it from rotating
PM me a couple pics like the ones i posted.
