StrokexBore Combo for a LSX block based nitrous motor
What would be a good bore x stroke to use?
I was originally going to build a stock block 408. Should I still use that cubic inch just in a LSX block.
I was also looking at a 4.0 stroke 4.125 bore motor for 428cuin motor.
I want to make sure that I have enough compression height/piston deck on the pistons and obviously with more stroke the thinner the piston gets.
I do like a 4.1 stroke 4.125 bore 438cuin, but I'm not sure I could spray a lot of nitrous on that piston.
This motor will have TF GenX255 LS3 heads, with a vic jr (for now) with a single stage fogger.
I want to be able to spray 400hp+ on this motor.
Thanks,
Since every 0.10" of stroke is only worth about 10-11 cubes I would think a 3.9" stroke would be a good choice. It would give you another 0.10" of journal overlap (compared to a 4.0 stroke)...beefing up the weakest spot on the crank and allowing for additional C/H on the piston.
Just my .02
Not saying a 4" is a weak set up (I have a 4" myself). Just the OP expressed concern about compression height so I offered a solution. At the level he wants to be I doubt he'd miss 10 cubic inches.
1.2x Compression height would be great for "Heavy" nitrous use but you're not going to get that in a std. deck height and make cubic inches. That's where 9.8" deck height blocks with a 4.25" stroke come in handy.
A 4" stroke with a 9.24" std. deck height will net you a 1.115" compression height. Many have used this with very good success.
A 3.9" stroke would give you a better compression height then a 4" like was mentioned earlier by 74u and would work well also. ( don't know C/H off the top of my head)
Both the 4" and 3.9" will work fine.
