Stand alone fuel system
Old Sep 2, 2014 | 09:01 PM
RobsZ28's Avatar
Default Stand alone fuel system
I think I know the answer already, I just want some clarification. I have a Nitrous Outlet 98-02 F-Body Fuse Panel stand alone fuel system with the aluminum tank in my car. The wiring diagram shows a ground wire going from the tank to ground. Since the tank is bolted directly to the car I don't need to have that wire to ground the tank, Correct?
Old Sep 3, 2014 | 08:59 AM
brandon@nitrousoutlet's Avatar
The fuse panel dedicated in an F-body doesn't have to be grounded as long as it is mounted straight to the radiator support but the battery tray dedicated would need to be.
Old Sep 18, 2014 | 01:23 PM
imma_stocker's Avatar
I think that extra ground is to release static build-up that could potentially ignite fuel vapors inside. My tank is plastic and I'm still going to add a tank-chassis ground wire.
Old Sep 18, 2014 | 03:36 PM
The fuse panel dedicated is bolted metal to metal on the radiator support.
