New kit setup questions
I've already got a basic kit but I had a few questions about how to set it up and what electronics to use.
The car already blows the tires off in first so I don't want to spray in first gear at all until I'm able to fit a bigger tire. I'd like something that has a first gear lockout if possible.
I've also never had a kit setup on a dbw car. Is there something I can use for a wot switch other than hooking a microswitch to the pedal. I thought ls2 cars had a different tps signal so I'm not sure what tps wot switches will work
I think something with a window switch, gear lockout, and tps switch is what at I need, just not sure what product does all three.
This sounds like exactly what you are looking for. It is a progressive controller, but its also got a built in RPM window switch, WOT/TPS switch, and a first gear lockout setting. It will also progress the nitrous if you need it to, to help with traction.
Let me know if you have any questions, or if you need pricing.
Thanks,
Garrett
Was looking at the fjo and nitrous outlet tps/window switches and It looks like they both have a gear lockout.
Are either of these still available or would I just need to search the classifieds
Thanks,
Garrett
Big thumbs up to nitrous express for a sweet product and willingness to offer a suggestion.
All my other stuff is from nx, just don't have the money right now
I remember the nitrous outlet and fjo controllers being a decent amount cheaper, just don't know if they still make them
