Need a little help with one electrical connection
Old Oct 4, 2014 | 04:36 PM
02TransAm/Batmobile's Avatar
Default Need a little help with one electrical connection
I'm installing my HSW interface and need a little help with the instructions.
HSW says to, " Connect the BLUE wire to the triggering device. This could be a RPM Window Switch, TPS/WOT Switch or Push Button (it is not suggested to hook up to an arming switch.)
I have the Tick Performance window switch and I'm not exactly sure what to connect the blue wire to. I narrowed it down to 3 possible connections of the window switch:
- Blue (which is connected to the TPS or WOT switch)
- Green (which is connected to the RPM or Tach wire)
- White ( which is connected to the arm switch)
I'm guessing I should be connecting blue to blue but I'd like to be 100% sure.
Thanks in advance!
Old Oct 5, 2014 | 10:54 PM
inssanity21's Avatar
Blue makes sense because that is what activates the nitrous.
Old Oct 6, 2014 | 08:29 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Needs to be connected to blue, or the WOT wire. The RPM window switch works off of the ground wire on the relay.
-Garrett
Old Oct 10, 2014 | 09:28 PM
Thanks guys! I will connect blue to blue.
