Verifying lnc-2000 timing retard
You can confirm that the LNC-2000 is taking out timing by monitoring the output voltage on the analog output wire. The analog output wire (gray wire) provides an output of the amount of timing retard being taken out. It is a 0 to 3 volt signal with 0 volts being 0 degrees and 3 volts being 15 degrees. You can record this analog voltage with EFILive, HPTuners, DashDAQ or many other devices. EFILive has a pre-configured math channel for the analog voltage to convert it back into timing retard. You could also use a volt meter (on DC volts) to see the voltage.
You can also physically confirm that the LNC-2000 is taking out timing by using a timing light.
If you are testing to see if it is taking out timing, keep in mind that the LNC-2000 will not taking out timing below 1000 RPM so be sure to test above that RPM.
I hope this helps and thank you for purchasing LPE products.
Also for those that want to add a meter, a standard +12 meter will not work for a few reasons. Need to get a digital meter, one for an electronics panel. It will need to be a 3 or 4 wire DC unit. Most of the panel meters need to be powered by 5 volts, not 12-14. Even if the meter states 10 volts, it will eventually burn up. Just need to add a 5 volt regulator, about the size of a power transistor and only a few $. Make sure the meter has enough resolution and reads to 1 or 2 decimal places. If the meter is not zero'd, a variable resistor, potentiometer, can be added. Mine is off by .01 on the meter, but idc, just need to know that it is active. .2 volts/degree.
