bad nitrous or bad bottle?
Old Nov 6, 2014 | 10:28 PM
03EBZ06's Avatar
whaz up Tyler.
check:
1. Relay. Could be intermittent and burned.
2. N20 Solenoid. Enough amperage and line size? Flow Tested?
3. Make sure pickup is not loose in bottle and is pointed down.
4. Drain bottle completely before getting it refilled.
Old Nov 10, 2014 | 02:45 AM
tyler ovel's Avatar
Hey Paul
Thanks for the advice. But I've already changed the noids both fuel and nitrous, checked all grounds, replaced a relay and this bottle was completely drained before refilling. And like I said in the original post I have narrowed it down to the bottle because I let that flat black mustang use my bottle when we rented the track out and it was doing the same thing to his car. Then when I emptied the bottle barely any white came out. I'm going to check the pick up tube before I refill the bottle. But force fed doesn't have any nitrous right now Idk if kieth is gonna get some anytime soon.
Plus I need to get this clutch fixed first lol.
Old Nov 10, 2014 | 09:45 AM
brandon@nitrousoutlet's Avatar
Have you pulled the valve from the bottle and checked the siphon tube?
Old Nov 13, 2014 | 12:50 PM
tyler ovel's Avatar
No I haven't. Been really busy lately.
