Piston rings for nitrous or.......
Old Feb 15, 2015 | 08:22 AM
Mac86's Avatar
Default Piston rings for nitrous or.......
I am in the process of building my ls1 it'll be 50-50 street/ track car, Not my daily! Looking to spray 200. I have PRC 5.3 2.5 heads for it, head studs, fast 92mm, Longtubes etc.. etc.. My question is I'm pulling the engine all the way down, I was planning on keeping stock rotating assembly and putting "better" rings in it more suited for nitrous. What would you reccomend ring wise. Or would getting piston and rods be better for the long haul. Thanks
Old Feb 15, 2015 | 09:03 AM
WE TODD DID's Avatar
Reuse the stock rings but regap them accordingly.
Old Feb 15, 2015 | 04:00 PM
Mac86's Avatar
Where should I start with gap size, is there a rule of thumb or formula for figuring gap? Thank you for the help.
Old Feb 15, 2015 | 04:41 PM
M.BOZZ's Avatar
I gapped mine at 23, 25, I think some guys are goi g to ask what bore it is or what does it say on the paper work. Bore x something, I never did figure out that part
Old Feb 15, 2015 | 08:23 PM
.006" x bore for top ring, add .002"-.004" more for the second
Old Feb 16, 2015 | 08:02 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This is a good idea for a budget build. Alot of high mile motors already have larger ring gap than factory spec anyways.
-Garrett
Old Feb 16, 2015 | 10:45 AM
LivernoisMotorsports's Avatar
If your going to take an assembly apart upgrading would seem logical.
We run the Total Seal AP rings on 99% of our builds. If you install those your concern will be the piston and the tune up and as long as the later is Johnny on the spot you should be fine.
