Standalone for nos
Old Mar 6, 2015 | 09:13 AM
cbnova's Avatar
Default Standalone for nos
Who sales the best one for 4gen camaro
Old Mar 6, 2015 | 09:18 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
http://www.nitrousexpress.com/15004-...-methanol.html
Here is the one we sell. It uses an Aeromotive regulator that comes with a low and high pressure spring, it returns right out of the tank. If you have us make a note we can configure it specifically for an F-body to fit in the battery tray. It will handle e85, race fuel, or pump gas. Let me know if you have anymore questions!
Thanks,
Garrett
Old Mar 6, 2015 | 04:46 PM
brandon@nitrousoutlet's Avatar
Here is a stand alone fuel cell made specifically for the 4th gen camaro. No need to move your battery. We have it available in plastic or metal. Check out the links below.
http://www.nitrousoutlet.com/dedicat...el-system.html
Old Dec 12, 2015 | 11:29 PM
AINT SKEERED's Avatar
I know I'm bringing up an old thread but can we get pictures of this mounted in a car?
Old Dec 15, 2015 | 09:10 AM
No problem! Check out this thread showing it installed:
https://ls1tech.com/forums/nitrous-o...lled-pics.html
Old Dec 15, 2015 | 10:00 AM
RENE'S RAGE's Avatar
That's the advantage of the aluminum vs the plastic?
Thanks
Old Dec 15, 2015 | 10:03 AM
ZackMorris's Avatar
If you shove the fuse boxes down by the fog light, you can stuff a generic RCI 1 gallon fuel cell there.
Old Dec 15, 2015 | 10:17 AM
Thanks
Really, just looks.
Old Jan 9, 2016 | 06:16 AM
Turbo5.0's Avatar
Is a return line from the regulator back to the tank required?
Old Jan 9, 2016 | 01:32 PM
RobsZ28's Avatar
Thanks
I have aluminum version. The aluminum looks better when new, but the seal around the lit seeps fuel out. It eats away the paint below the tank and discolors the hold down ring and screws. The plastic has a screw on top that probably won't seep and costs less. If I had to do again I might consider plastic, but do really like the look of the aluminum when new.
Old Jan 10, 2016 | 09:42 AM
Yeah, I'm leaning towards the plastic one. I like the screw on lid also.
Old Jan 11, 2016 | 11:17 AM
Call me and I'll get a gasket sent to you.
Old Jan 12, 2016 | 08:42 PM
SRTKLLR's Avatar
When we are not going to run nitrous we usually drain the dedicated tank because it also leaks.
It is a 2010 Camaro dedicated but we put it on the Silverado when the Camaro was sold.
Old Jan 17, 2016 | 07:35 PM
RobsZ28's Avatar
Thanks, to Brandon and Nitrous Outlet's great customer service mines back to looking new again.
Old Jan 18, 2016 | 09:05 AM
AJatNitrousOutlet's Avatar
Good deal, man. Let us know if you need anything else!
Old Oct 19, 2017 | 02:30 PM
z twenty h8's Avatar
Bump for info on how to get a replacement gasket for my nitrous outlet stand alone...
Old Oct 19, 2017 | 04:10 PM
Just call the shop. They're only $6.
Old Nov 24, 2017 | 08:14 AM
pantera_efi's Avatar
Default Propane Tank + NOS
Hi All, many of us in Calif. run a Propane BBQ tank in the Trunk for the NOS fuel.
There are some PROBLEMS :
No Fuel Pump is required as the "bottle" pressure is 200 PSI.
The Octane is ONLY 130 RON.
The fuel cost is TOO LOW with a common price of $1.85 a gallon.
The Liquid Propane when injected will LOWER the combustion temperature making more power.
The Purge of the Liquid Propane leaves no fuel (liquid) when at the line.
Lance
Old Nov 26, 2017 | 09:10 AM
Carter01's Avatar
I've ran the nitrous outlet plastic fuel cell for several years. Very nice unit and affordable.
