Car on E85, stand alone on race gas?
on another note I really appreciate you guys (NX) and Nitrous Outlet always answering questions and helping us out. My only reason still staying nitrous. I have a brand new turbo kit for my car that I bought from a vendor who didnt answer my questions and I thought maybe that he sees that I bought it anyways he would answer some now and still no answers thru email's or calls. So it sits in boxes. I'm just amazed and yes I didnt expect immediate answers but after a month with no communication. (sucks) enough of my rant.
thanks again Andel
Let me know if you come up with anymore questions man!
Thanks,
Garrett
To the OP, just put E85 or E98 in your stand alone and bump your fuel jetting by 20%. It will be much easier to tune in the long run.
Injecting two different types of fuel into an engine works great and is nothing to be afraid of. Think about all the people that have been successfully spraying methanol on top of a gasoline fueled engine for years. I do recommend using a wide band to tune a dual fuel type setup and it is simpler for most people to understand the correct fueling when you speak in Lambda terms instead of AFR (since lambda remains consistent between fuel types and stoichiometric AFR does not). In most street nitrous applications we recommend targeting around .80 to .85 Lambda. It is worth noting that .80 Lambda will display as 11.76 on a gasoline specific wide band gauge or as 7.81 on an E85 specific wide band gauge.
Why not put e85 into the stand alone and let it eat?
Mine runs on e85 with e85 in the stand alone so there isn't a drop in the pressure causing a lean spike.
There are a few good reads on yellow bullet about this same subject if you would like to do some reading. Most everyone was echoing the same thing as Brandon.
Regardless. Those guys that are spraying meth on top of gas powered motors are likely running forced induction rather than nitrous. We have customers running alcohol and spray leaded race gas on top of it. With the jetting they are on, we are actually getting enough fuel from the enrichment side to see it on the plug. What if the guy is running a direct port? Do you still tune it off the wideband that is just gathering an average across all 8 cylinders? What is the point of having a direct port then if you can't correct cylinder to cylinder? How about just avoiding all of this and running the same type of fuel in the car and tuning it right?
