Going 125+ wet on head/cam
Old Apr 6, 2015 | 05:20 PM
1ta ls1's Avatar
Default Going 125+ wet on head/cam
So I've been considering installing a EFI wet kit at 100-125 shot on top of my current build:
I made about 422rwhp/398rwtq on the dyno last year on stock plugs.
LS1 Block
224/230 .581/.590 114 lsa
Stage 1 PRC Heads - LS6s
TSP Headers7/8 - Catted Ypip
Borla non-adj w/ cutouts
Yank Pro 3600
3.42 gears
Bosch 36lbs injectors on Stock Fuel pump
I'm new to the nitrous systems. going to use a progressive controller, bottle heater and purge solenoid. Any recommendations/thoughts?
Old Apr 6, 2015 | 05:34 PM
HCI2000SS's Avatar
I run a 125 wet shot on my HCI LQ9. Its a NX single nozzle wet kit and i use a LNC-2000 to pull timing. You should be fine as long as you pull some timing, run the plugs and have adequate fuel.
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
First thing I'd suggest would be to upgrade the fuel pump to a 255 w/ hotwire harness so you know your covered on fueling.
After that other than the system for a good core setup would be to get a controller [ Window switch or progressive ], N20 gauge, and bottle heater [ Would suggest fully automatic version ]. Purge is purely optional IMO but nice to have to clear the line or show off .
Also feel free to holla at me here at the shop and I'd be more than happy to ask any questions or go over any concerns you might have.
-Chris
Old Apr 6, 2015 | 05:41 PM
1ta ls1's Avatar
I have the bottle heater, NOS progressive controller, and a purge. last time I ran on a dyno, I was close to full duty on the stock pump and 36lb injectors. I was hoping not to change the stock pump and injectors and spark plugs yet.
Old Apr 6, 2015 | 05:42 PM
HCI2000SS's Avatar
Originally Posted by 1ta ls1
I have the bottle heater, NOS progressive controller, and a purge. last time I ran on a dyno, I was close to full duty on the stock pump and 36lb injectors. I was hoping to get away with not changing the stock pump and injectors and spark plugs just yet.
Bad idea man!
Old Apr 6, 2015 | 05:48 PM
ragtopz28's Avatar
-Chris
You have been advised!
Old Apr 6, 2015 | 05:51 PM
1ta ls1's Avatar
new fuel pump it is. spark plugs for my build?
Old Apr 6, 2015 | 05:53 PM
HCI2000SS's Avatar
Smart move BR7 plugs gapped around .30 -.35
Old Apr 6, 2015 | 06:07 PM
ragtopz28's Avatar
Yep...I run mine @ .032
Old Apr 6, 2015 | 06:15 PM
1ta ls1's Avatar
Cool. Lots of good info. Gonna grab a new pump and plugs. 36lb injectors sufficient?
Old Apr 6, 2015 | 06:24 PM
HCI2000SS's Avatar
The 36's will be fine
