More Nitrous Woes
Old Oct 3, 2004 | 04:52 AM
Dirty Vegas's Avatar
Not an error, maybe poorly worded. Usually I only pick up 20 mph in the 2nd half of the track.
Old Oct 3, 2004 | 10:37 AM
hellbents10's Avatar
LS1Tech Sponsor
So seven more then usuall in the big end eh.
Old Oct 3, 2004 | 02:13 PM
2000TransAm24's Avatar
Oh ok I thought you meant you gained 27mph on top of your current N/A trap speed. My bad I don't think it was poorly worded, just poorly read by me.
Old Oct 5, 2004 | 12:16 AM
StraightlineInc's Avatar
Any bottle that is less then a 5lb bottle doesnt have a siphon in it, so it must be used upside down. A 2.5 bottle will work with dry shots because the pressure at most point doesnt matter because it doesnt need to mix(fog). If its a wet shot then like they said pressure drops to quick and you end up spraying basically more fuel and barely any dense nitrous.
Also I would never in my life run platinums in a car with spray. Everyone talks of saftey and the first thing to go that should be changed is a good plug.
