This cam for nitrous and how to be safe? Newb.
i have ms3 cam
ai 241 / 219cc heads
42lb green tops
92 / 92 intake combo with fuel rails
twin disc clutch
was thinking about changing up the cam, but if the powers that
be think the ms3 cam would work well in the upper rpm ranges
with spray, i may keep it in there.
Wider lobe separations and longer exhaust durations will help out tremendously with the tuning window and performance. I would always go with a custom grind over an off the shelf if it makes sense.
I would talk to Brian (Brian Tolley Racing) and see if it would make sense with your build to switch to a custom gride or just wait until you go with a new motor or make a head change.
I would save up for some good heads, the casting and the power is a world of a difference. That afetrmarket casting will take the heat and stress a lot better than the factory casting.
