Blowing purge push buttons
Old Aug 5, 2015 | 03:40 PM
AJatNitrousOutlet's Avatar
Originally Posted by Firehawk441
Wire it correctly with a relay.
This!
Originally Posted by badbubba
Is the switch rated at 8 amps ac or dc? Many times switches are rated at an ac amperage. If rated for ac, the dc rating would be much lower. Probably around 2 amps. Iirc, my NO purge is around 8 amps. Plus, your probably not capturing the in rush "spike" current, which then drops as the magnetic field saturates and then stabilizes.
And this. Well said bud.
Old Aug 5, 2015 | 07:04 PM
Canderson1434's Avatar
Originally Posted by imma_stocker
Use a doorbell instead. DONE
So far the toggle switch has been working so I'm just gonna stick with that lol.
