Adding a second stage
Old Sep 5, 2015 | 04:36 AM
slowsol95's Avatar
Sounds like Nitrous Express needs to take better care of who they give the password to lol
Old Sep 5, 2015 | 10:06 AM
gagt3100's Avatar
Car is a grudge car. I don't want to run a timing box, I'll just have static timing pulled. Just wanted to know if it will be effective or if I should get a fogger and just spray more at it . I can get it bought , plummed and flown for 1600 through a local shop.
Old Sep 8, 2015 | 11:48 AM
brandon@nitrousoutlet's Avatar
It would be faster on a single kit with how you are wanting to set it up.
Old Sep 8, 2015 | 06:02 PM
gagt3100's Avatar
How much can I spray through this puck ? I'm at 300 now , can I do 400 safely ?
Old Sep 8, 2015 | 08:46 PM
4wheels's Avatar
Default Timing retard
The LNC-2000 is an easy way to do the timing retard but if you don't want an additional timing retard box you could do it in the ECM/PCM calibration. If it was an ECM/PCM that has an available EFILive custom OS you could even have the second state activate the timing retard (using a timer out or some other similar output from your nitrous system). Works well and even lets you change the fueling when the second stage kicks in if you want.
Old Sep 9, 2015 | 09:00 AM
AJatNitrousOutlet's Avatar
Sure can, it will flow just a bit over that with no jet.
Old Sep 9, 2015 | 02:27 PM
TyCZ28's Avatar
.... Im glad this got back on subject. I about facepalmed myself out of my desk Andy. Now for the benefit of the OP and any of our customers who might have this question in this situation would you rather them run a Stinger plate or TB plate for the second stage or a single nozzle on the button with the puck flowing the primary kit. A dual stage puck would be killer in this situation.
