Direct Port Nitrous Conversion
Current set up
current pile of parts (it's an old pic, none of it is in the packaging anymore lol)
The nozzles I will be using. Now, they are unique in the industry. Most nozzles are either 1/16 NPT or 1/8 NPT. This means you have to tap the manifold PERFECTLY so when tight they are all the same direction. These nozzles are 5/16-24. All I have to do with these is put some loctite on them, thread them in until I want to stop, snug the jamb nut, and let the loctite dry. Hell, you can even go without the jamb nut.
What I am going to - except the hard lines will be replaced with braided stainless lines, and the name of my shop will be engraved on one of the flat sides.
Overall, this kit will be good for up to an 800 shot hahaha. Right now I am limited to a 200 - 250 shot as that is all my supply line will support. If I upgrade from a -4AN to a -6AN I could realistically spray 300+ if I use race fuel for the nitrous fuel enrichment. IF I decide to stay spray and on #TeamNoBoost, I will redo all the wiring potentially this winter and move all the relays and fuses to the underhood fuse box. THAT will be quite a task, but will make for a super clean installation.
My new switch plate is ready to be hooked up. However, I am toying with the idea of changing the switches out to billet ones - just for the added prettiness lol.
Not my pic, this was taken by the guy who made the plate for me. When I get it wired in and **** I will take a better pic of it lit up.
I was tempted to buy another FAST dual channel but I like the standard gauge mounting of the Innovate.
Are you going to use the wideband sensors upstream?
New headers are here finally!
and the 3" x 3" x-pipe to go with it. Once I get it set up so I know how it needs to be adjusted, I am going to wrap it with DEI Titanium wrap.
Had a new wide band delivered today as well since my Autometer **** out on me. Innovate DLG-1 dual wide band
Going to reseal the diff (as I think the seal between the trans and the diff is cut) while I am in there. Now I just need to get the nitrous rails from the machine shop. Lotta work to do this weekend....
don't forget to film it haha.
