Direct port progressive
Old Oct 26, 2015 | 06:30 AM
stherngent's Avatar
Default Direct port progressive
Whats a good proggressive for a direct port?
Also I have a nos mini right now using with my direct port, when we spray the nitrous is beating the fuel to the cylinders by .2-.3 can I put my nitous on ch1 and fuel on ch2 and delay the nitrous by .2-.3 to compensate and allow both to get there same time?
Thanks for any help
Old Oct 26, 2015 | 06:45 AM
ATwelveSec02Z28's Avatar
Lingenfelter NCC is the best. Or the NLR NMS.
Both are set up to control nitrous and fuel solenoid independently, so you can start with a higher percentage from the fuel to fix the lean spike
Old Oct 26, 2015 | 07:56 AM
stherngent's Avatar
Yea I was reading about the NMS-1000 it sounds pretty good.
Old Oct 26, 2015 | 08:00 AM
stherngent's Avatar
I'm trying to make Radial Fest this coming weekend. was able to make it to dyno this past saturday and came across this problem. My nos mini only has ch2 so we weren't able to try both channels and split the nitrous and fuel to see if we could run it that way just to get us thru the weekend. My buddy also has has a nos mini so i borrowed his hoping it would work to get us thru the weekend and then gonna order something different.
Old Oct 26, 2015 | 09:30 AM
AJatNitrousOutlet's Avatar
You can run the fuel and nitrous solenoids on different channels, but you'll need to run a large relay on the nitrous side. Then, you can adjust the delay accordingly-
Old Oct 26, 2015 | 09:46 AM
stherngent's Avatar
Thanks AJ , how big of a relay im showing 11.5 amps on nitrous solenoids or 23 amps together. I'm thinking 30amp would be enough.
The nos mini provides a ground for signal where do I need to install the relay? My mind is racing at the moment trying to make sure I can make this race for the weekend.
Thanks
Old Oct 26, 2015 | 09:59 AM
stherngent's Avatar
Old Oct 26, 2015 | 03:15 PM
Which solenoids are you using? The Mini has a load rating of 40 amps per channel, so as long as the solenoids aren't pulling that much you should be fine without the relay. However, most nitrous solenoids will pull more than that-
Old Oct 27, 2015 | 06:54 AM
stherngent's Avatar
I'm currently using the NOS super pro shot 11.5 amps X2 and NOS cheater fuel @ 2.8amps X2
Thanks
Old Oct 27, 2015 | 09:31 AM
You should be fine then running the fuel on one channel and nitrous on the other without a relay.
Old Oct 31, 2015 | 08:26 AM
Hardcoresoldier's Avatar
I am using the NOS Mini Progressive II on my 4 solenoid direct port. I know the single channel won't support all 4 solenoids, so I am just going to use both channels (1 channel per bank) and have them both come on at the same time. Next year I intend to upgrade to a better controller - maybe the Nitrous Outlet Pro-Max.
