using nitrous like a turbo?
Old Oct 26, 2015 | 09:04 PM
fastbird02's Avatar
Default using nitrous like a turbo?
ok, i am brand new to nitrous. just set up my wet plate kit will just about all the add ons, including a progressive controller. which is what got me thinking. if i ran a good size turbo that didnt start to spool up until around 3k until shift point. Could the same be done with nitrous? start progressively around 3k and ramp it up to shift point. I hope I am explaining what i am thinking correctly. basically what i am thinking is could i use nitrous like a turbo with an on/off switch? If this is the dumbest idea you have ever heard, please dont flame too much. Just thinking out loud...
thanks for your time, and input.
Bruce
Old Oct 27, 2015 | 07:25 AM
HCI2000SS's Avatar
Let me 1st ask what size shot so you wanna do?
Old Oct 27, 2015 | 07:49 AM
fastbird02's Avatar
i was thinking of a 100 shot
Old Oct 27, 2015 | 07:51 AM
HCI2000SS's Avatar
Then none of this will be necessary just so you know
Old Oct 27, 2015 | 09:26 AM
98redorangeta's Avatar
You can use a progressive controller to ramp power in like boost but unless you have issues with traction or are using a bigger shot you just want the full 100 all the time.
Old Oct 27, 2015 | 09:29 AM
AJatNitrousOutlet's Avatar
On a 100 you should be fine without ramping it in. Even if you were to ramp it, you would want your ramp to be as short as possible. The progressive function is simply a traction aid, and most will ramp to 100% in less than a second or so. Drawing your ramp out for an extended period will interfere with your tune-up.
Old Nov 4, 2015 | 07:27 PM
krissoto's Avatar
U would never want to spray under 3k anyway.
