FAST / NITROUS OUTLET question
Old Dec 16, 2015 | 10:46 PM
b0b's Avatar
b0b
Default FAST / NITROUS OUTLET question
I am fixing to run a plate kit off the rail with a 92/92 setup. I was wondering if it would benefit to run the FAST rails with feed and crossover lines versus the stock rail setup? Will the nitrous outlet plate setup even work with a FAST rail??
A few details..
HC sbe ls1
42lb injectors
255 pump, hot wire kit
Plan on 100-175 hit
Thanks
Old Dec 17, 2015 | 08:45 AM
AJatNitrousOutlet's Avatar
The FAST rails are much better than the stock rail, especially when pulling from them to enrich the nitrous. We can modify the kit so that it will work with the FAST rails, just give us a call!
Old Dec 19, 2015 | 04:39 PM
ZackMorris's Avatar
Fast rail with a NO dual stage plate works just fine.
FAST / NITROUS OUTLET question-yu8vcol.jpg
Old Dec 29, 2015 | 04:30 PM
b0b's Avatar
b0b
That is a nice *** setup. How do you have the fuel coming from the Y to the noids and also coming into the rail? Do you have a standalone or do you have another Y somewhere that splits between feeding the rail and the noids?
Old Dec 29, 2015 | 05:30 PM
ZackMorris's Avatar
Standalone where the fuse box used to be
