ZEX LS1 Kit
Old Jun 12, 2004 | 03:19 PM
zyal8r's Avatar
Exclamation ZEX LS1 Kit
Please Post Opinions of the ZEX Kit for the LS1,
Thanks for the help
Old Jun 13, 2004 | 09:41 PM
Nitro Dave's Nitrous Outlet's Avatar
The zex kit is a good kit if you are looking for no more than a 125hp shot gain.It is also very easy to install.If you are looking for higher hp gains you may look into a NX kit.
Dave
Old Jun 13, 2004 | 11:34 PM
blackws6-02's Avatar
i love mine.3 wire hook up.kit will regulate fuel and nitrous based on bottle presure.i am running a wet kit .
Old Jun 13, 2004 | 11:54 PM
SSpeedracer's Avatar
Anyone know how it meters fuel based on nitrous pressure? Does it cycle the fuel solenoid if nitrous pressure is low? Or, does it just not turn on until nitrous pressure is achieved?
Is a fuel pressure switch part of the box?
The Zex kits looks interesting. What all does the controller do?
Old Jun 14, 2004 | 12:08 AM
everthing is in the little purple box.if pressure is to low it wont come on.iam not sure if they have a built in fuel switch.but i can remove my fuel supply line and it will not spray,so it might have 1 of some sort.sounds like it dont it.
Old Jun 14, 2004 | 01:19 PM
Black- thanks for the answer here and pm.
I just spoke with tech support at Zex and apparently there is neither a fuel pressure switch or a nitrous pressure switch. This contradicts both the zex published info and what you have experienced. So, I guess the tech support doesnt know their product too well. The tech guy said the only control is from the throttle body sensor. He also suggested a fuel pressure safety switch. Supply line is 16ft.
Old Jun 14, 2004 | 01:54 PM
Humanoid's Avatar
NitroDave...can you tell us how this system works and if you have very many customers using it sucessfully?
Old Jun 14, 2004 | 11:45 PM
you may have talked to someone at comp cam.they are the same people. iam running kit 82023.it is for a ford.the only difference between the kit for the ls1 and mine are the line lengths
Old Jun 15, 2004 | 11:21 AM
Fast94bird's Avatar
Zex I believe has 2 differnet kits. wet or dry. The dry kit can only be used on a return style fuel system. Here is how it works. Your vacuum line to the stock regulator is cut. both end connect to the nitrous box. Under normal non nitrous useage the reagulator works as if nothing has changed. but start spraying and a very very small amount of nitrous is sent to pressuring the fuel regulator, which make the fuel pressure go up. Now the pressure rise is controlled by nitrous bottle pressue and different jetting. the more pressure the more fuel rise. The only problem I have seen with this type of set up is, if the line comes off the regulator there is no fuel rise, boooommm. The wet systems work the same as all other wet, no fancy control box, just 2 noids in a enclosure.
HOPE THIS HELPS
Old Jun 15, 2004 | 12:10 PM
Fast 94 bird.Nailed it pretty well.
Sorry I was swamped yesterday and did not have time to answer post like usual.
Dave
Old Jun 15, 2004 | 07:42 PM
ss rally red's Avatar
Dave whats your price on the Zex wet kit? I tried the website with no luck. Thanks
Old Jun 16, 2004 | 01:51 PM
579.99.Sorry we are still working on the web site.
Dave
Old Jun 22, 2004 | 09:36 AM
98ls1's Avatar
whats the price for the zex dry kit
Old Jun 22, 2004 | 02:29 PM
Sorry they do not offer a Zex Dry kit for the ls1.However if you are looking for a simple dry kit with good quality you can not beat the our dry kit.
Dave
