Return for stand alone
12-801-1
Red Electric Fuel pump, Street Perf.
97 gph (free flow) 67 gph at 5 psi
Regulator not required for most applications
712-801-1
Red Electric Fuel Pump, Marine
Scott
Appreciate the help guys
Have you considered a smaller fuel cell? I'm restricted on space so I'm going to use a 1-quart Moroso aluminum overflow container.
Scott
I have a cell, battery, and a bottle in the trunk.....had to "seal off" (build a real fire wall)
In regards to your Fbody stand alone for the fuse panel area... Does your kit need a return line? It looks as if it just dead heads from the regulator to the noid... And there are 3 open ports on the regulator... One would go to the noid, the other gets capped and what about the other? Does that one get capped also?
Thanks
Thanks
Thanks!
