Should I use the Microedge I have
Old Feb 21, 2016 | 11:07 PM
springer_4's Avatar
Default Should I use the Microedge I have
My question is should I install and use the MicroEdge Nitrous controller I have sitting around or should I sell it. First off I'll list my set-up and use, I'm running a Nitrous Outlet Plate kit with all the goodies, Blanket, Purge, LNC-2000,NOS window Swtich. Gonna run a 200Shot. Mostly for the street, might see Drag Strip 3 times a year. So should I install the controller and set it at 100shot and then work it's way up too the 200shot.
My SET UP
Fresh 1998 .10 over Block
Stock Rods/ARP rodbolts
New Cast Pistons
LS6 Intake/PP TB
Tick Street Heat cam 231/235 | .625”/.605” | LSA113+3
799 Heads/Pac Springs
Morel 5160 lifter/Trick Flow 7.4 Pushrods
Speed ENG 1 7/8 Headers
Magnaflow CatBack
Racetronix Fuel pump/Hot wire
6-Speed/Spec Stage 2 Clutch.
Founders Suspension/Panhard/LCA/Torque Arm
3:90 Stock 10bolt
Torque thrust 10"/315 Nitto 555r on the rear.
Old Feb 23, 2016 | 09:41 AM
AJatNitrousOutlet's Avatar
There shouldn't be anything wrong with using that controller for what you're wanting to do. If you want to get something else though, I'd recommend using the NOS Mini. The Mini is a easy to use, reliable little controller that's great for street cars that occasionally see some track time.
