Would a nitrous controller help your 60ft?
I was curious if a nitrous controller like the NOS 2-stage or a NX TPS/WOT switch help benefit me? Would it make the system "hit" harder off the line? Not sure if I should stick with what I have or spend the money if it'll work. Thanks
Basically I've been thinking about getting rid of the WOT microswitch and get a controller with the TPS switch built in. So I was curious if I switched to that, if it would activate sooner, therefore "hit" harder during the launch? I hope I'm making sense here lol.
Either this NOS 2 step:
http://www.nitrousoutlet.com/electro...ow-switch.html
The NX unit:
http://nitrousexpress.com/18959-nx-d...-required.html
I like these units also because they have a window switch, which I don't at this time. So it would be safer for me as well. Just wanted your guys input on these units. Thanks
What do you think a "cam-only+150" should 60'??
I'm full weight+...so over 3600# and even with it coming in 10-15' out still managed a 1.53. With your weight and a dead hit I would think mid 1.4x's
Next time I go out to the track I need someone to record me from the side so I can see how it takes off
