Direct Port Help
Old Mar 10, 2016 | 02:01 PM
04goat350's Avatar
Default Direct Port Help
I am thinking of swapping out my current plate kit for a direct Port system on my GTO. I have figured out the kit I would want and thanks to Nitrous Express they will be doing the work on the intake and plumbing it up if I got this route. my question is that since there will be 2 Fuel and 2 nitrous solenoids I know how were I am going to run the line for the Nitrous but I am stuck on the best way to get fuel from the rails to the solenoids. I am not looking to do the NX rails on top of the fuel rails but rather the distribution block they offer on each side. any advice would be great thank you.
Old Mar 11, 2016 | 09:06 AM
04goat350's Avatar
ttt..
Old Mar 14, 2016 | 10:14 AM
AJatNitrousOutlet's Avatar
What fuel rails are you using and what fuel system are you using?
Old Mar 14, 2016 | 03:57 PM
04goat350's Avatar
I have factory rails on the LS6 intake. And fuel system I have not looked into much I am still kinda doing research on this and learning
Old Mar 14, 2016 | 04:44 PM
LivernoisMotorsports's Avatar
how bout from your 1 gallon fuel cell that you keep race gas in.
That has a dedicated high volume fuel pump to feed the solenoids only(base this pump off of the most your will ever use and over kill it)?
A short dedicated fuel system with controlled fuel is the winning ticket on a good N2o set up.
Old Mar 15, 2016 | 07:16 AM
04goat350's Avatar
Do you have a kit for a stand alone Fuel system?
Old Mar 23, 2016 | 09:24 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
We can definitely get you covered for fuel plumbing whether you are using factory rails or you end up going with a direct port. Depending on how much you're wanting to spray you really might look at going the dedicated route.
-Chris
Old Mar 24, 2016 | 11:00 AM
Nitro Dave's Nitrous Outlet's Avatar
As mentioned above the Dedicated fuel system is usually the best answer on a GTO due to the way the fuel system is designed. How much are you looking to spray? What does your engine combo consist of?
Dave
Old Jan 13, 2017 | 01:08 PM
04goat350's Avatar
currently looking to spray no more then a 200 shot but once I build up a new motor with stronger internals could be looking to spray more.
