Nitrous and 2 step
Old Apr 3, 2016 | 08:13 AM
BODYSHOPGOAT's Avatar
Default Nitrous and 2 step
BEEN DOING A LOT OF RESEARCH ON N2o controllers I have a currently have msd 2step wired into clutch pedal sensor wire going into computer I'm now adding nitrous outlets nozzle kit and doing 150 wet shot. This is just for this year before stroker build. What I'm trying to find out is.....what's the best option for me? I hear a lot about the nos mini progressive controller and lingenfelters but I do not want to change my msd 2 step box. Also I have seen the micro storm. Just looking for something cheap that will work with my 2 step
FOUND OUT I WILL NOT BE RUNNING A CONTROLLER JUST NEED TO FIGURE OUT A TIMING BOX AND HOW TO TURN NITROUS OFF WHILE ON TWO STEP
Old Apr 4, 2016 | 04:13 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
You might look at our Maximizer 4 controller. For the cheap option you might look at this diagram...
You can use this for a 2 step also.
-Chris
Old Apr 14, 2016 | 04:08 PM
94Z28Joe's Avatar
I have the msd 2 step and timing tuner. I have the 2 step set at 3k and the timing tuner set at 3500. works like a charm.
