Questions about the lnc2000
Old Mar 11, 2016 | 09:17 AM
k_garretson23's Avatar
Default Questions about the lnc2000
Currently I have an MSD 2-step. My question is does the lnc2000 allow you to pull timing only with the nitrous system is activated? Also for the 2-step feature is that only when the system is armed or would I be able to use it on motor as well? Ive always just ran my nitrous tunes 100% of the time n/a or not and Im sick of having my car run like a dog without spray but Id like to still have a 2step n/a.
Old Mar 13, 2016 | 08:46 PM
Sail Hatan's Avatar
yes, mine pulls timing as soon as i flip on the nitrous arming switch. also the launch control is a separate feature. Mine is wired to my clutch switch. I actually have mine set up to flip flop. when i hold the clutch in in interrupts the nitrous, so i can have it armed and still use the launch control. second i release the clutch it will spray, and it will retard timing. won't spray between shifts etc. quality unit and very easy to wire.
Old Mar 14, 2016 | 09:55 AM
AJatNitrousOutlet's Avatar
The LNC-2000 is a great plug-n-play timing retard for the LS engines. It'll pull the timing only when you activate the nitrous system, and the 2-step is activated off of the clutch switch. It's capable of pulling up to 15* of timing, so it should fit most peoples needs. If you have any other questions about it, or want to pick one up give me a call at 254-848-4300 Ext. 104!
Old Mar 17, 2016 | 02:31 PM
awesome thanks!
Old Mar 25, 2016 | 09:02 AM
Originally Posted by k_garretson23
awesome thanks!
No problem! Let me know if you need anything else!
Old Mar 30, 2016 | 01:28 AM
NOS LS1's Avatar
I Run a 150 shot on **** Calif. 91 Octane Pump Gas. Im pulling 8 degrees of timing with my LNC 2000. No Rattle or Detonation. Awesome set up.
Old Apr 5, 2016 | 07:55 PM
Zmg00camaross's Avatar
You ever try and put some timing back in it?
Old Apr 13, 2016 | 01:06 AM
SoonerBrad88's Avatar
What do you use to interrupt the power to the nitrous? I'm about to do the same to a friend's car and basically what I came up with was installing an additional relay between the 2 step relay and the nitrous power line.
Old Apr 14, 2016 | 04:53 PM
efuehrin's Avatar
subed.
