need help on fuel side adding regulator for nitrous
Old Apr 9, 2016 | 01:50 PM
erskine's Avatar
Default need help on fuel side adding regulator for nitrous
i added a 2nd reg for the nitrous side, i Y off the main feed, and both reg are bypass style. so the 2nd reg that i added wont adjust and only stays or mirrors the engine reg psi. im lost on what to do here now
Old Apr 9, 2016 | 09:25 PM
jerr6's Avatar
read #2 https://aeromotiveinc.com/frequently...ed-regulators/
if you run some sort of return you will prob end up needing 1 bypass reg and 2 deadhead regs.
you can increase pressure high enough on bypass reg to feed 2 deadhead regs like the link suggests
or
put 2 deadhead regs on a fuel log with a bypass reg on the outlet of the fuel log back to the tank.
