solenoid bracket for four solenoids...
I'm looking for a bracket that will hold the solenoids (four) close to the 4150 throttle body and one on each side or coming off of each corner. All I can find are brackets that have two niods to the front and two to the back. This sucks because getting to the back ones are a bitch being under the cowl like that. Plus they are sort of huge putting them very far from the throttle body. Any suggestions, with pictures? What are you guys doing?
I don't have a double sided bracket but you can stack these with a gasket in between. Might work for you. -Matt
http://www.nitrousoutlet.com/nitrous...-solenoid.html
