HELP: NOS WOT/window switch
Old Jun 20, 2016 | 11:22 PM
IronThomas's Avatar
Default HELP: NOS WOT/window switch
I'm running a Nitrous Outlet plate kit. 125 wet shot, with the NOS WOT/window switch. I am SUPER pleased with it and how easy it is to install and use.
I am new to nitrous, this is my first kit. One thing I am having a problem with is the huge delay I have for the kit to come on. Is this normal for nitrous kits?
You really notice it from a roll. I'll bring the rpms up passed the minimum rpm I have setup (3500) and when I put the pedal to the floor there is about a full half second delay before the kit activates.
Now, I know this is no big deal from a dig or at the track. But when it comes to roll racing, it's cost me one race. In that time, allowed the car to jump out a good car, and having 4.10s ran out of gear before I could make it all back up. Anybody else having this issue? Do you all just go WOT a bit early, like in an auto car?
Thanks in advanced
Old Jun 21, 2016 | 03:26 AM
HCI2000SS's Avatar
I had that issue, and in my case it was the traction control module causing the delay, so I disabled it
Old Jun 21, 2016 | 07:50 AM
IronThomas's Avatar
Are you talking about what comes on an auto car?
Old Jun 21, 2016 | 07:57 AM
HCI2000SS's Avatar
No mine is a manual.
Old Jun 21, 2016 | 10:25 AM
IronThomas's Avatar
What did you do to disable it. Worth a try for me I guess
Old Jun 21, 2016 | 10:34 AM
Nitro Dave's Nitrous Outlet's Avatar
It should be instant when you are WOT and meet the parameters with the window switch. Press and hold button #1 and see if the display on the window switch rpm is the same as the rpm on your dash.
Old Jun 21, 2016 | 10:38 AM
Also are you using TPS signal or WOT switch?
Old Jun 21, 2016 | 10:48 AM
IronThomas's Avatar
That was my first thought, the rpms are lower on the NOS box. But I figured that since it was reading from the PCM the box displays actual rpm and the dash is off some. So when I did my test hits I was WELL above the window (about 1000 rpm above).
I am using WOT switch built into the NOS box I got from you which reads TPS voltage. Set the voltage at 4.5 which I verified by activating the NOS box and went to WOT in which it slowly raised and reached 4.5 volts when I got to WOT.
Old Jun 21, 2016 | 11:09 AM
If you hold your rpms on the dash at like 2500 rpms, what is your window switch reading?
Old Jun 21, 2016 | 12:02 PM
IronThomas's Avatar
I can give you exactly what it reads later today, but from memory 150-250 rpms lower than what the dash shows.
Old Jun 21, 2016 | 09:36 PM
IronThomas's Avatar
What mode should I be using?? I've heard of some guys using the 4 cyl mode for some reason?
Old Jun 22, 2016 | 08:40 AM
Where did you tap the wire into for your tach input?
Old Jun 22, 2016 | 08:58 AM
IronThomas's Avatar
The instructions just said for "ignition wire". For my vehicle PCM there are two. Ignition control and ignition module. I chose the wrong one the first time.. as the rpms did not show. So I tapped into ignition control and that enabled the rpms to display on the NOS box.
Be advised, the system activates and deactivates per the on and off rpm windows..
However. There is ALWAYS a good half second delay between WOT and the kits activating. No matter the gear and how far above the minimum rpm set.
Old Jun 22, 2016 | 09:03 AM
Did you set the tps voltage .2 lower than WOT voltage?
Old Jun 22, 2016 | 10:26 AM
IronThomas's Avatar
No. I was afraid that doing that. Will activate the kits before WOT (fuel system acting under WOT conditions) but I will try your advice.
Old Jun 22, 2016 | 11:56 AM
http://www.nitrousoutlet.com/media/t...h_15982NOS.pdf
Scroll down till you see
2.5 Configuring Settings of the NOS WOT / Window Switch
Then read the note.
Old Jun 22, 2016 | 12:08 PM
It may be taking just a split second to read exact WOT voltage which could be causing the delay you are experiencing. -Matt
Old Jun 22, 2016 | 12:19 PM
IronThomas's Avatar
Just read the "NOTE:" portion of section 2.5. It says to input .2 volts lower for my 4.5 volt reading. I will adjust and try again. Thanks for your help guys.
Old Aug 2, 2016 | 08:30 PM
IronThomas's Avatar
Still cannot run down where this delay is coming from. It's about the same length of time it would take for a stock auto to downshift after you go WOT.
Any M6 guys running the NOS window switch have this issue?
Old Aug 2, 2016 | 11:32 PM
tug686spd's Avatar
Does this happen in every gear or just the initial hit?
