HELP: NOS WOT/window switch
Old Aug 2, 2016 | 11:34 PM
IronThomas's Avatar
Originally Posted by tug686spd
Does this happen in every gear or just the initial hit?
The initial hit
Old Aug 2, 2016 | 11:39 PM
tug686spd's Avatar
New to nitrous but seems if it was electrical it shoul happen with every gear as the system is cycling with the shifts. My first thought is do you have a puge?
Old Aug 2, 2016 | 11:41 PM
IronThomas's Avatar
Right it doesn't make any sense. Yeah I have a purge kit.
Old Aug 2, 2016 | 11:54 PM
tug686spd's Avatar
I was kinda betting on the no purge since it was only the initial hit. Now about the only thing I can think of is maybe getting some tip in knock at first hit and computer pulling timing then adding back.
Old Aug 5, 2016 | 09:15 AM
IronThomas's Avatar
Does anyone know which ignition mode to use (1995 LT1) for the NOS window switch? (Example: I've heard LS1 guys use the 4 cylinder mode since it's a coil to plug)
Old Aug 8, 2016 | 10:31 AM
AJatNitrousOutlet's Avatar
It depends on where you're getting the signal from, however for the LT you should probably need to be on 8CYL mode depending on where you get your tach signal from. The best thing you can do is start it on 8cyl, and see if the RPMs match what's shown on the controller. If not, you'll need to change the modes until you find one that does match.
Old Aug 8, 2016 | 09:11 PM
jblankenship's Avatar
Set the lower rpm to zero. Then test fire the system with the car off but ignition on. See if there is still a delay. How long are your nitrous lines. Post an underhood pic.
