Nitrous outlet fast 90 install? Will stb still work?
I bought a fast 90 nitrous outlet kit and was wondering which bolts you mount the brackets too? I can't find instructions for the fast 90 but I'm assuming it's the same as every other ls1 98-02 f-body kit . It looks like a pia to reach the bolts to get the solenoid brackets on. Do you have to remove anything to reach the bolts ? And I have a strut tower brace and was wondering if I can use it with this kit not sure if the lines will clear?
Thanks
Thanks
Check these images out for solenoid bracket placement.
http://www.nitrousoutlet.com/efi-wet...te-system.html
I think it's the 3rd bolt from the front that bolts each bracket in place, and the skinnier one is on the right side. Make sure you attached the solenoids to the brackets first using the two 5mm screws for each bracket, and then attached the straight NPT and NPT elbow fittings that go into the solenoids using blue loctite. Let the loctite dry overnight. Do this on all NPT fittings or their will be leaks.
Once that is done, attached the brackets with the solenoid on them to the intake, and then attach the hardlines where they mate up to the solenoids. The AN fittings on the hard lines will be attached to the TB plate last.
You may need to remove the strut tower brace if it's in the way.
And check out this link here: https://ls1tech.com/forums/nitrous-o...tall-pics.html
Thanks
Thanks
