Help me out 5.3 build
Old 09-08-2016 | 08:09 PM
06murder's Avatar
Default Help me out 5.3 build
I'm wanting to spray my 5.3 06 Silverado. What would be a good setup, cam intake converter gears so on.
Old 09-08-2016 | 09:39 PM
Dennis5374's Avatar
I'm assuming the truck is 2wd? If so I'd run 3:73, get a converter s pecifically made for nitrous , I had great luck with a 4l60 and a Hughes stall with lockup . It was street friendly it flashed around 3600 in my car, and I could foot brake it to 2800 to launch. As for a camshaft, go with a custom grind . Your 5.3 is tough as nails. "I have a 5.3 turbo Camaro in my shops parking lot that's a straight junkyard motor with ls6 intake, a cam, arp head bolts, and stock heads. The car is making well in excess of 600 at the tires. Tomorrow night were running meth and 19 lbs of boost from a on3 76mm turbo. Mind you this is a 250.00 dollar motor and refuses to give up with the almighty lsx sin" retorqued stock rod bolts 😳" To avoid buying a fuel system to support it , id suggest a "dedicated nitrous outlet stand alone fuel system " it hold 1 gallon of your choice of fuel and has its own fuel pump. For 700 this is some reassurance as there are multiple parts involved in a vehicles fuel system , and when one fails it can be the end of your engine
Old 09-08-2016 | 09:44 PM
Dennis5374's Avatar
http://www.nitrousoutlet.com/efi-wet-nitrous-systems/gm-systems/plate-systems/gm-99-06-classic-gm-78mm-truck-plate-system.html
this is right up your alley , and if you'd like I can send the link to the stand alone fuel system. Id also like to add that a good running "safe" nitrous setup , is gonna cost you as much as a cheap on3 turbo setup. I'm over 1500.00 deep in mine and intend on another 1500.00 going towards it for the lingenfelter nitrous controller , as well as the dedicated fuel system .
Old 09-13-2016 | 09:52 PM
ianp2009's Avatar
Originally Posted by Dennis5374
a good running "safe" nitrous setup , is gonna cost you as much as a cheap on3 turbo setup..
im learning that this is a very true statement.... i got a good deal on my kit then all of a sudden im going to have over twice as much in just my accessories lol
Quick Reply: Help me out 5.3 build
