Low psi nitrous with efi
Old Nov 7, 2016 | 10:03 AM
cdmartin's Avatar
Default Low psi nitrous with efi
If u have a car on EFI, and want to add an additional fuel cell for a stand alone nitrous system is it possible to use low psi for the nitrous like with a carb? I've got a spare holley blue and 1 gall fuel cell. I have a single nozzle, was thinking of putting all tgis on my stock 5.3 for about a 100 shot. Run fuel pressure at around 6psi and use the carb style jetting. Anyone done this?
Old Nov 7, 2016 | 10:11 AM
brandon@nitrousoutlet's Avatar
That will work fine. Low pressure will allow you to have some more tune-ability in the system as well.
Old Nov 7, 2016 | 02:15 PM
cdmartin's Avatar
Awesome thanks for the reply. I thought it would work just fine but waneed to be sure before trying. I think it should be good up to 150ish hp. Low buck setuo since I have everything. It will allow me to run c16 on the spray. 1 gallon of c16 on a 100 shot should last several runs
Old Nov 13, 2016 | 08:21 AM
Bowtiedford's Avatar
1 gallon will last a few bottles lol. Just make sure if your using low pressure that its rock steady at the psi you intend to run. 1 pound difference is a lot on a low pressure system. If you look at a jetting chart.
