E85 Tune up
Being under timed can kill a motor in 1 pass! Just depends on if it is severely under timed or slightly under timed.
E85 is showing to not want the tune up that gas does, meaning 2* for every 50hp of n20 jet may not hold true. That could be the the wrong tune up and hurt the motor on larger hits. And heck, +200rwhp with a single 57n jet....
Flame speed is going to dictate amount of advance required, and combo coupled with lambda is going to dictate flame speed. This is why I am suggesting starting small and step up incrementally.
Hi Brandon,
I quoted and made the key issues in bold.
I would agree with you that 23* is over timed for a 250 hit with a Lambda of 0.85. Put it at 0.77 Lambda (11.3 AFR on the gas scale) and that 23* might not be over timed.
I would argue that AFR has a bigger impact in actual cyl temps, the plug is just along for the ride. A hotter plug is going to melt down sooner than a cooler plug. I will also argue that a plug can be cooled some with additional fuel.
