Please Help with NX Maximizer 4
Old Apr 1, 2017 | 03:15 PM
Freshsqueezd's Avatar
Default Please Help with NX Maximizer 4
I installed it and solenoids won't come on rpm and tps reads perfect I am activating it through the tps wire it reads 0% when the throttle is closed and 100% when open but solenoids won't arm at all any help please?
Old Apr 2, 2017 | 09:31 AM
baronsmith98's Avatar
Open the software and make sure your input #2 is set to "do nothing". I had the same issue as you and couldn't figure it out and I finally saw where my input 2 was set to "arm stage" so without this input seeing signal my solenoids wouldnt open
Old Apr 3, 2017 | 02:44 PM
That was the problem thanks man
