Nitrous only sprays in first?
Old Apr 2, 2017 | 08:32 AM
Jtm2085's Avatar
Default Nitrous only sprays in first?
I took the car to TNT yesterday and tried out my nitrous outlet plate kit for the first time. I had the car on the dyno a few days ago and made a pull with 150 shot jets with out issue (only picked up 129hp/120tq). My issue at the track is the car only sprayed in first gear. After I shifted to second it was all motor for the rest of the pass. It did this for two runs. Full bottle minus the dyno run, pressure was 950, I am using a jegs brand window switch set 3600-6300.
Old Apr 2, 2017 | 12:42 PM
455GTO's Avatar
I had the exact same issue when i was running the Summit brand window switch and no matter what setting i chose for activation it would not turn the nitrous back on after i reached the high rpm setting on the window switch. I ended up removing it and no more issues. You will be better off with the NOS mini controller which has more features if you really want a window switch. If not, take it out and throw it away. I battled that damn thing for a while before removing.
Old Apr 2, 2017 | 01:36 PM
Jtm2085's Avatar
Thanks for the response bud. Yea I had a feeling the window switch would end up being the culprit.
