Knock Sensors Pulling Timing
Setup is a forged 370 with ported 243 heads running 9.6:1 CR and a procharger at 11psi. These runs were on a 9 NGK plug running E67 gas (flexfuel) and 10.5 gas scale AFR. I locked the timing in at 14 degrees. I almost seems like there is too much heat buildup or the rings are too loose after the engine gets hot causing this to happen. I will post some plug pics later and I still need to pull the other 7 to see what they look like. Any help is appreciated.
