2-step with a wide open throttle system
Do you guys just say **** it and let it spray and pop the **** out the exhaust while your sitting on the line or do I need a progressive controller? Thanks
On trans brake cars we just use a relay to interrupt the power to the nitrous until the TB button is released.
Anymore input would be greatly appreciated
simply put...
Relay 1
30 - 12v from battery or ign on source
85 - 12v activation from 2 step button
86 - Ground
87 - 12 Output to 2 step controller
87a - 12v output to relay 2 pin 30
Relay 2
30 - 12v from pin 87a of relay 1
85 - 12v activation from Nitrous Activation button
86 - Ground
87 - 12 Output to Nitrous Controller activation or to WOT window switch
87a - Not Used
effectively, pin 87 is used when you activate the relay coil by putting 12v to pin 85
pin 87a is the wire that comes out of the coil when you dont have power to pin 85
so when you hold your 2 step button, nitrous is off..but you leave it armed and ready to go...
when you let off the 2 step button, it sends voltage to the Nitrous kit and away you go...
safe and reliable
simply put...
Relay 1
86 - Ground
Relay 2
86 - Ground
87a - Not Used
safe and reliable
Have a wire from that relay and a wire from the two step going to the clutch switch. Any time clutch is pressed, nitrous is turned off and two step is activated. Been working great for a while.
It'd be the same wiring for a trans brake interrupt
What do you think of this? I have not tried it but like Tyler, looking for
2 step solns for 6spd. This prevents the 2 step from activating on movement. Not sure if the VSS (pin50) will work as I think.
you cant use a vss signal...it is not a 12v signal...its a magnetic pulse that goes on and off rapidly
When I used to run a 2step I think I had it wired into a switch up at the top (like a cruise deactivation switch), but I'm not sure if it should be there or at the bottom.
my 2 steps wired to bottom starter enable switch so with clutch is at bottom 2step is armed and the nitrous goes through MSD rpm window switch throttle body WOT switch fuel pressure safety switch and then the cruise control switch at the top of the clutch pedal so once clutch is out it starts spraying!!!!!!!!!! works great clutch is 2step on drop clutch 2step shuts off nitrous kicks in!! and hits like a 3500lb hammer off the line
