Fuel Rail Covers with N2O outlet 92mm fast plate system?
I'm wondering if there is a way to customize these covers so that the plate system in the 2nd link can be used? Maybe cut some slits and feed the solenoid brackets through the cover? Has anyone seen this done before? I suppose the other option is to not run hard lines to the plate and just mount the solenoids somewhere else.
http://www.ebay.com/itm/GM-LS4-8-5-3...303e51&vxp=mtr
http://www.nitrousoutlet.com/efi-wet...te-system.html
