300 shot..... How do my plugs look?
I know this pic isn't the best and I left my dremel at the house, but can anyone tell me how this plug looks from this angle?
I'm not sure what's going on with that. The only variable that's changed is I went from B8EFS to B9EFS.
2013 camaro SS, stock ci, stage 3 heads Wiseco pistons, K1 rods, 235/242 .603/.618" 114 cam. I was pulling 11 degrees of timing through an Lnc2000. This is also on a NX Direct Port with 31n 26f jets on 5psi. I'm not sure what my timing is on the motor, it was remote tuned
Yeah I kinda figured since my phone camera kind of stinks and my flash wouldn't work due to low battery. When I get this lean condition figured out I'm going to take more pictures
You really need to know what your timing is on motor only.
Not trying to be a dick, but a 300 shot on a SBE is something you don't need to take lightly. You're going about it all wrong right now. Imo.
Seriously if you're spraying 300, leave the antiseize at home. It will strew your plug readings. You're looking for heat in the threads. If your threads have gunk on them you'll never know the true reading.
Maybe I'll take a reading of a couple without antiseize on them and see how they look for a reading.
I'm running Sunoco 116 in a stand alone and 93 in the tank. Usually my wideband says 10.9:1 but for some reason it's giving me a reading anywhere from 17-20:1 WOT on the bottle. Even my N/A afr has changed according to the wideband. It's usually consistently 11.8:1 and now it's 12.5-13.5:1.
I found out after troubleshooting that I had my fuel solenoids channel set to a 1 sec. Delay! Ouch. I'm still trying to figure out why while n/a I'm 13:1 when before yesterday I was always 11.8:1. I don't want to spray again with new plugs until I sort that out. Any ideas?
Hi Boone, thanks for the reply.
I USE Copper Slip (Jet Nut), this also helps keep the plug cooler, the steel.
The read is best taken by observation of the ground strap for AFR.
I like to see 50/50 with "sharp edges" as if new.
I like to see the insulator as a piece of white chalk.
I like to see the "fire band" 1/2 of the insulator length.
The chance NOT to damage a piston IS based on a correct Spark Instant.
Many her will state "other" AND never report EGT.
My friend Mike Thermos (Nitrous Supply, NOS) supplies that same tech as I state AND ADDS when the NOS/Spark/Octane is correct you may often "see" an EGT DROP when under "spray".
You may want to install an EGT gauge ?
Yes, send better pics.
Please STATE the UEGO sensor and Gauge brand ?
The stated WOT ARF could be just a "fouled" sensor = "0" voltage report = bad read form no output caused by your too rich AFR.
Lance
Lance
Lance
Lance
I noticed a bit more fouling on cylinder #3 plug than the others. Would that make the wideband pick up a leaner reading?
