nx nitrous lnc2000 window switch wiring help
Old Jun 26, 2017 | 08:57 PM
gapinyou's Avatar
Default nx nitrous lnc2000 window switch wiring help
Hey everyone new to the ls based cars and trying to help a friend with a 2000 camaro 6 speed
Looking for diagram nos/lnc2000/summit window switch
Hey guys helping a friend with a 2000 ls1 6 speed camaro
He has a Lingenfelter lnc2000 right now he is using for launch control
He is wanting me to wire the nitrous and he has micro switch mounted on clutch pedal and has a summit digital window switch he wants to add in also .
Does anyone have a diagram ? looks i only need orange wire from lnc2000 to retard timing how do i wire this in to the window switch and nitrous relay
The summit instructions are as follows
red to 12v switched source
black to ground
gray for tach signal
blue to negative side of what im powering
also where do you pick up tach signal on ls1
Old Jun 27, 2017 | 07:23 AM
gapinyou's Avatar
Sorry had it posted as a 3000 its a 2000 box
Old Jun 29, 2017 | 03:52 PM
Jtm2085's Avatar
I got my tach signal from the pcm. Be careful with the summit window switch. I had a jegs brand window switch and it wasn't compatible with my car with out a tach booster. I ended up going with a msd.
Attached Thumbnails nx nitrous lnc2000 window switch wiring help-photo281.jpg
