Plug read opinion
The Timing "steel read" is NOT in focus.
I see a small amount of "bad" steel on the center electrode ?
I think 28* is a high Advance Value.
Lance
What I need is to see the edges of the ground strap for metal loss.
I seemed to see this on the center electrode.
Did you TDC the timing marks for "0" alignment ?
The 28* could be anywhere.
Another way is to "pull" the timing when at 32* WOT NO NOS finding the point of a LOSS of Torque.
Then do your -4 retard.
What is your local track's Altitude ?
Lance
Lance
This altitude CAN require a more advanced Ignition Timing event. (+2*)
OK, the GM EMS CAN verify TDC "0" by the OEM grade software/firmware fitted.
The MSD 6014 IS NOT ABLE to do this correction.
NOW I ASK 24xe or my 58x (60-2) as the Target Wheel Tooth Count ?
Lance
AFTER MANY (100+) observations, the MAX 58x IS + 1.75 for a TDC "comp" as Common.
Thus I STATE a "safe" Spark Instant, though NOT "measured" BUT COMMON.
Lance
And I wouldn't put much faith into what panara bread guy says. He will probably tell you to run a tr6 gapped at .050".
My customers, many, race in LONG races such as BAJA (250, 500, 1000 miles)
After the race they bring me the Spark Plugs AND filters both Oil and Fuel.
MY INSPECTION of the Spark Plug's sharp edges, with a correct tune, IS AS NEW just as when the box is opened.
The use of a #7 (pictured) now looks good and with a HP (200) increase there will be more heat.
I also use Brakleen (Brake Parts) to wash the "soot" away from the plug surface.
I would like you to view the Autolite 3922x Racing Plug for track use.
This plug is designed for NASCAR use in a CUP engine.
Lance
sometimes if I have to I will stop and pull just one plug (usually from the hottest cylinder if I know which it usually is) and throw a used one in that I keep in my jacket, then fire the car up and make it back to the pits.
IS there an alternative or are you just sortof "up a creek" if you don't have a good place to pull of/someone to tow you back
