Pressure washing engine with nitrous solenoids?
Old Oct 19, 2017 | 02:39 PM
Whisper's Avatar
Default Pressure washing engine with nitrous solenoids?
So my engine/engine bay desperately needs to be washed and I was wondering if there were any additional concerns with spraying high pressure in/around/on nitrous solenoids? Its a standard wet kit with the NX solenoids mounted near the fuel rails on a FAST 92mm intake. I'd ask in Appearance but I figured I'd get a more informed response here.
Edit- I should mention this is with a 92mm plate kit, not a nozzle.
Old Oct 19, 2017 | 03:14 PM
BudRacing's Avatar
There is really no need to pressure wash an engine bay of a running/driving vehicle. With the engine warm, cover any sensitive items with plastic grocery bags and sweep out any leaves or other large debris. Rinse with a standard garden hose nozzle--I like the "shower" setting. Spray whatever degreaser of your choice in there. I like Simple Green. Use an agitator brush (or clean paint brush) for the textured areas to loosen dirt and debris, and rinse again. Repeat if necessary.
Old Oct 19, 2017 | 03:56 PM
Zmg00camaross's Avatar
I'd use a spray bottle with some diluted simple green and give her thee ole hand job, then rinse and wipe off.
Old Oct 19, 2017 | 04:10 PM
MY_2K_Z's Avatar
Yep diluted simple green spray down the whole engine bay and rinse. I personally have no issues using a pressure washer on engine bays. You just have to keep your distance to like 18 inches or more and it won't hurt anything. I then like to blow it all off with compressed air or a leaf blower. Water hoses are useless lol
